Old 11-26-2014, 11:43 AM
Steve149's Avatar
Steve149 Steve149 is offline
Default Quick Question
I was going to take my Dash tin off for some well needed rejuvenation, but how does the hydro control lever come off? Is there a set screw in it...I can't see it that well my freeking eyes don't work like they used to!
Old 11-26-2014, 11:51 AM
There's a set screw in it, its under were the lever sticks out.
Old 11-26-2014, 11:53 AM
Steve149's Avatar
Thanks Tim I thought that's what it was...but I need to make a trip to the eye doc and get some new lenses. No matter how much light I put on it I couldn't tell what it was
Old 11-26-2014, 06:23 PM
Maybe it is not in there,did you try using the correct allen wrench in there?
You can feel around in there for it.
Old 11-26-2014, 06:40 PM
What model tractor?? Some of them screw off and on Ya know, the knobs on the levers I mean!
No!!!.....Wait!!!!, NOW I know how I ended up with so darn many of these things!!! I swear there was another one in my storage shed last time I looked!
Old 11-26-2014, 10:54 PM
I believe it's a 149
Old 11-27-2014, 07:42 AM
Steve
They can be a PITA to get off. I managed to get the set screw out of mine but the splines on the inside of the lever had worn so I ended up drilling a hole through the top of the lever, put a socket head bolt through the hole and used a puller to get it off. When I put it back together I drilled through the set screw hole, the shaft and out the other side of the lever and tapped it for a socket head bolt. Not pretty but it works.
Old 11-27-2014, 10:05 AM
snoel's Avatar
snoel snoel is offline
Thanks for posting the "picture story". I have not had to remove it from my 149 yet. But, the tin needs replacing. So, eventually....
Steve
Old 12-01-2014, 11:15 AM
Steve149's Avatar
Steve
Thanks Sam...I managed to get to it...been fighting a freeking cold all weekend. I had to put the cheaters on to see it better. I was bit tough coming off the splines but is popped loose after a few colorful adjectives...
