Old 11-01-2014, 06:35 PM
gdheck's Avatar
gdheck gdheck is offline
Default How does foam go on 2072 firewall?
Just a couple small bits of foam were still on the firewall of my 2072 when I got it. I have the new pieces of foam, but how are they supposed to go on. I know the wide piece goes on the bottom and the long piece on top. It seems like they are too long to just make a circle. A picture would be a lot of help.
Thanks,
Geoffrey
2 Originals, 100, 105, 125, 1450, 1200, 2 IH 982's, 1211, 2072, 2-1864's, 1782, 3 - 42" front blades, 3 Haban 54" blades, Haban sickle mower, BB36, QA-36A, 42" IH rear blade, 42" IH landscape rake, #1 tiller, #40 box blade, 59M shredder, #2 cart, International 3312 push mower, International 250 power washer, 1952 IH refridgerator, 1971 IH 1210 3/4T 4x4 truck
Old 11-01-2014, 06:53 PM
The foam just makes a circle around the blower inlet. No big deal. Pic is the best I could do for you. # 14&15
Old 11-03-2014, 03:33 PM
gdheck's Avatar
So just the ends of #15 have anything to stick to? There's nothing else down there on the firewall. Or does it actually stick to the bottom of the blower housing?
Old 11-03-2014, 04:34 PM
Here is a pic of an 1872, looks like the foam is glued to the fire wall.
Old 11-03-2014, 04:44 PM
Yes, just like Sam said the top goes on the firewall. The other piece goes (attaches) on the bottom of the blower housing. It seals against the engine mounting plate.
Old 11-03-2014, 04:45 PM
jimbob200521's Avatar
Maybe this pic will help, you can see the one in the foreground but also notice in the background is another machine with the same foam setup. Hope this helps
-Ryan
Old 11-03-2014, 05:09 PM
Ryan, the foam setup on the V-Twins is different from the H-Opposed motors. On the V-Twins, all the foam goes on the firewall. On the opposed, one half on the firewall, other half on the blower housing.
Old 11-04-2014, 01:16 PM
gdheck's Avatar
Ok, that makes a lot more sense now. I just couldn't imagine the bottom piece staying on long if it was stuck to the firewall. There was nothing to go by on my 2072 and my 782 has had most of the stuff under the hood parted out already.
Thanks for the pictures guys!
