Old 09-23-2014, 06:59 PM
guido guido is offline
Default loose steering arm @ spindle
I have found two possible procedures for repairing the fitment between the steering arm (pitman arm) and steering knuckle.
1) taper pin
http://spaco.org/loose.htm
2) drill oversize and new spiral pin or bolt
http://www.************************.com/steering.htm (scroll 1/2 way down page)
Looks like OCC doesn't like that link...
Which method is preferable?
regards,
Alan
Old 09-23-2014, 07:04 PM
IHinIN IHinIN is offline
The bolt method is the worst because it will never fit the hole tightly and it will end up wearing the hole even more. I repaired my 100 using a tapered pin. If you go that route, you'll also need the correct tapered reamer too.
Old 09-23-2014, 07:29 PM
I've always drilled mine and used a larger roll pin.
