I have a 124 with a Bosh coil and point saver. The points slipped and stayed open all the time so I had to re-time it. The previous owner put a nice white timing mark on the flywheel so I used that and gapped the points at 0.02. It runs and idles really smooth now but hits really hard at least once every time I try and start it. It hits so hard the starter will stop rotating. Is the timing too advanced and do I need to gap it at 0.018 to correct it? Thanks
Time it this way, don't worry about the gap.
http://www.onlycubcadets.net/forum/s...ead.php?t=4405 Bill |
Put it in the list of accepted sites. Sorry if that sounds blunt, but it's much easier for you to read through Matt's link than to write a whole new one explaining it.
I will try again tonight on a different computer. Thanks
Time that engine according to the instructions that came with David Kirks point saver. I have also found that if remove the original adjusting screw from the points and replace with an allen head screw the points will stay where you want them.
Don B, USAF 1962-1968, Ft. Wayne, IN |
I think you can open the cam cover on the left side of the engine and manipulate the spring on the cam (if it's not broken) back into place to get the compression release to work again. Or so I've read on other threads here, but have never attempted it myself. (yet).
that is an excellent PDF write up!!! Thanks Dbuck for the tip!
![]() Cub Cadet 1250 w/ the K301aqs engine. Restored to 1978 Columbia City, Indiana |
Your are Welcome.
If the problem persists after the spark timing procedure already outlined has been performed, try using a premium fuel. Ethanol enhanced fuels cause all kinds of peculiar problems in older engines.
Queen Of The Quietlines!
