I'm in the middle of a Kohler K301 rebuild. I was looking at the posts for ideas and hints. Lots of info on this site and everyone seems so helpful. So I have an idea I got from a Model A engine I pulled out. To lift those heavy Kohler engines you can make a lift ring. I took an old spark plug, knocked the porcelain out, tapped the hole with a 3/8" tap and screwed in a ring. Screw the unit in the spark plug hole and lift it up with your lifting device. It may not be perfectly level but it is easier to handle. Just make sure your threads from the ring go all the way through. If one 3/8" ring can lift a Model A in a spark plug hole, it will lift a Kohler.
That works! Tho I'd be afraid of stripping the threads out in the head. I usually take two headbolts out and thread in two eye bolts. If I have to lift it with a winch. Most of the time I lift by hand with a swift back wrenching motion.
Cubs: 2072 w/60" Haban, 782 w/Johnson 14 loader & 44" deck, & 169. Others: Ford 120, Ford LGT100, Ford LGT125, 2 - Ford LGT145s, & 4 - John Deere 140, H1 and H3. |
Rant from j mech beginning in 3..2..1 go
I've got a tab for a hook on the top of my K series that is OEM. In the event of an engine pull, I'll use that.
If you take the gasket off the bottom of the plug it gives you more threads in the head.
Sorry...... I'm late.
That is a very, VERY, VERY bad idea ![]() BTW. A model "A" has a CAST IRON cylinder head...... And I still wouldn't pull even that engine like that. |
![]() Quote:
![]() I do it the hard way, I just grab a hold of them and lift. Then my back lets me know for a couple days that I'm not all that smart. ![]()
![]() Quote:
But not the KT's or the Mags...... nope. I'm not "man" enough for those. ![]() |
![]() Quote:
-Ryan
![]() Quote:
-Ryan
