Old 08-18-2014, 06:59 AM
rebel715 rebel715 is offline
Default So close, but yet so far......
I received my new clutch drive plate and clutch disc assembly and reinstalled everything in the tractor, and connected the battery and started the tractor. The new rubber engine mounts were quiet and doing nicely, the all of the sudden, the tractor sounded like someone sticking a piece of half inch re-bar into a gear at speed!!! Sparks were flying...... Anyway, upon inspection, I have an issue with the new clutch. The new clutch drive plate (stock) does NOT have the bronze bushing welded into the center of it as did the one I just replaced. The whole drive line was all over the place because of it, and I had to unbolt the engine again and remove the clutch drive plate assembly, and try to contact the distributor today to get the "right" part. I'll get there someday I guess!!! I may need to rent some goats in the meantime. LOL!!
1977 IH Cub Cadet 1000
Old 08-18-2014, 10:14 AM
That bushing is probably sold separately so its not included with the driver.
Old 08-18-2014, 10:21 AM
Thanks, I called the distributor this morning and found out the same thing. The bushing is now on order and hopefully will be here by the weekend.
