Old 08-08-2014, 07:40 AM
GrotenhuisCubs's Avatar
GrotenhuisCubs GrotenhuisCubs is offline
Default Snubbers
Can someone explain what the snubbers do on a ql engine cradle. Are they just extra support or?
104 puller, 1200 puller, 1450 toy!
Old 08-08-2014, 07:46 AM
The snubbers prevent the front of the engine tilting forward when an attachment or implement is using the electric PTO.
Old 08-08-2014, 07:51 AM
Default Thanks
It's on my 1200 puller so the pto never gets used, do you think I still need them?
Old 08-08-2014, 08:07 AM
jimbob200521's Avatar
Leave 'em on, think of the added weight up front!!
Seriously, though; if they aren't hurting anything, why taken them off? Do you still use rubber engine mounts or did you switch to solid?
-Ryan
Old 08-08-2014, 08:08 AM
bruce s's Avatar
bruce s bruce s is offline
If it is a puller I would use all steel mounts on the cradle . There is a vender that sales them here on OCC.
Old 08-09-2014, 07:48 AM
I wasn't going to take them off mine are missing and I just wasn't going to replace them!
Old 08-09-2014, 07:59 AM
If you pull it, you better mount that engine solid. Replace the rubber mounts with steal.
Old 08-09-2014, 09:36 PM
Solid motor mounts are $40 shipped complete with all hardware ( grade 8 flanged bolts and nylock nuts plus washers)
http://www.onlycubcadets.net/forum/s...ad.php?t=20875
Old 08-09-2014, 11:44 PM
Sorry Jeff, I always put a plug in for you and didn't this time. Not on purpose..... meant to and forgot.
Old 08-10-2014, 06:40 PM
No problem and thanks for the plug
