Old 07-06-2014, 10:10 AM
db4570 db4570 is offline
Default 106 Deck Doesn't Lift Very Much
I am enjoying using and tinkering with my new 106 and gradually fixing it up.
The deck can't be raised up very much. In the highest position it's just about right for mowing; the next notch down is way too low. The notches below that are unusable.
I have poked around the deck linkages and at first glance everything looks OK, but obviously something is wrong.
Any pointers on where to start or what to look for?
Thanks,
David
Old 07-06-2014, 10:15 AM
How about some pics of the machine so we can see if we spot problems. Pics are worth a thousand words.
Old 07-06-2014, 09:26 PM
Here are a few:
The deck was in the second-highest notch, not being able to lock into the highest notch for some reason.
Does this help at all?
David
Old 07-06-2014, 09:39 PM
moving the lift links to the rear set of holes will help a little, make sure the lift arms arnt hitting the frame.
Old 07-06-2014, 10:32 PM
Is it hitting the brake lever?
Old 07-06-2014, 11:25 PM
I don't think it's hitting the brake lever. That may be an optical illusion of the picture. I'll have to look at it again tomorrow.
It's a pain even to back it out of the shed to look at now because the deck is so low-slung it hangs up on the doorway threshold.
IIRC the raising lever is what seems to be bottoming out too soon on the frame. As though the shaft on it should have been welded on rotated about 20 degrees back from where it is. I'm still trying to get my head around how all the linkages work together.
David
Old 07-06-2014, 11:38 PM
on a side note i see in one of your pics that the rod running from the steering column up to the spindle is on the wrong side of the spindle, it should be on the bottom and not the top and every tractor ive ever saw like that has had less steering to the left than it did to the right.
Old 07-07-2014, 12:09 AM
Berwil's Avatar
Berwil Berwil is offline
Maybe a broken spiral pin on the rock shaft? Take the lift links off and try to push up on the tractor lift arms and see if they move up without the handle moving.
Bill
Old 07-07-2014, 12:29 AM
Bill
Manual rock shafts don't have spirol pins.
Old 07-07-2014, 12:33 AM
Berwil's Avatar
Doh!!
