I have this 124 with the mower on it. I put a new belt on it and it keeps coming off. Are there suppose to be 2 belt tensions on the mule drive or 1 tension adjuster and 1 spring?
also why we are at it, what to do with a PTO that keeps in gaged? 1st time doing it on this tractor
so many tractors, so little money |
![]() Quote:
gates belt from Napa, got the belt specs in another thread here.
when looking at the front of the machine, is the spring on the left pully and the threaded rod tension on the right? just wondering if it makes a difference. Pto lever can be forward, out of the normal on off range and it still runs.
Not all belts are Ag type belts that take the twists and turns that this Cub Belt takes. BTDT.
As far as the Mule Drive. See attached from page 3-7 of the Service Manual As far as the PTO, if adjustment don't cure the problem, then it is time for a PTO rebuild. The procedure is outlined starting on pages 2-60 in the service manual.
I agree with Roland. One other thing to check is the spindles on the deck. I was having the same issue. Checked the spindles and found the center one was badly worn. Just my
the deck on a 104 and a 124 are the same, are they? wondering if I have the wrong deck on it. thought they were the same decks.
got pics?
Measuring them will determine the size.
both have the same markings and id tags. I will go check again.
It doesn't matter. It is a NF deck.
even though they call for a 3/8 wide belt i always run the 1/2 wide husky belts from tsc, ive never had one come off and ive been running the same belts for 5 years and they still look new.
