Old 07-13-2014, 12:56 AM
bocephus1991's Avatar
Default Testing a 15 amp stator
I was looking in the tech library on how to test a 15 amp stator. I see that specs are .064 to .096 ohms . Is that bench testing or does it have to be tested while in operation?
Brian
Old 07-13-2014, 12:58 AM
Bench testing. I wouldn't suggest touching the leads when it's running. It puts out AC power.
Not to say you can't test the AC output..... just be careful. But, seriously, OHM checking is for when it's off.
Also, the test in the library specifically says "static test" which means, "not running".
Old 07-13-2014, 01:08 AM
yea you gotta be careful with ac power, i watched my cousin get lit up one time testing a stator.
Old 07-13-2014, 01:32 AM
Yeah, it'll make you holler!
Old 07-13-2014, 01:34 AM
That's why I asked, thanks Jonathan !
Brian
Old 07-13-2014, 01:35 AM
No problem Brian!
Old 07-13-2014, 07:26 AM
You NEVER check resistance (ohms) while under load or in operation.
Old 07-13-2014, 09:42 AM
Yes, your meter will get mad at you when you do that and might make you change it's fuse
Old 07-14-2014, 01:34 AM
Page 8.14 of the "Kohler Single Cylinder service manual" does a very god job of describing how to troubleshoot and test a 15 amp battery charging system.
