Hey guys, I have a 682 kt-17--of course, and have had it for years. How can I tell if it a series I or series II engine. I never could find the plate on the left side where it should be. Are there any other obvious characteristics that will tell me?
Thanks, I've been off the site for a couple years but now I want to fix it back up. |
The series 2 has an oil filter, the series 1 does not.
Travis 1993 Cub Cadet 2064 1988 Cub Cadet 2072 1980 IH Cub Cadet 782 w/CH20 1966 IH Cub Cadet 102 w/K301 1961 IH Cub Cadet O 1967 IH Cub Cadet 102 & 122 ![]() ![]() ![]() ![]() JD 2155 w/ 175 loader |
![]() Quote:
IF...everything is original, you can go by Chassis Serial Number of the tractor: Series I #669971 to 726124 Series II #726125 & above
![]() Quote:
The series 1's did not have the block off plate on the block to hook up the oil lines. As Roland said the early series 2's did not have an oil filter but I thought still had the block off plate but don't remember for sure. I will have to look at some of mine to see. |
![]() Quote:
I never have found a Kohler Reasoning to why some Series II had on oil filter and some did not. My "speculation" is, that is was buried into the "Specification" of the engine as to the buyer's requirements.
![]() Quote:
Another thing to maybe look at is the oil fill. All the series 1's I have seen have had the square cap and all the series 2's I have seen have had the round filler cap. Not sure it's a proven fact but it is a usually a good place to look. |
All the Series 1 i have seen had a pipe plug for the oil fill , and the Series 2 had a straight or angled pipe with a cap for the oil fill , if no one has changed it in it's life.
I have also seen them with/without the block-off plate. |
Sorry to jump onto someone else's topic, but were any of the MTD built 6/782s series I's? Reason I ask is I found a white/yellow 782 close but I couldn't see a block off plate through the grill.
RUN IN THE RED 782 w/50c deck (red); 782 dual stick, 44c deck (y/w); 1050 w/38c deck; 1864 w/54" GT deck; 1872 project Cub Cadet Pro Z 560 L 42" power angle snowblade, #2 tiller, 2-QA42a snowthrowers, 450 thrower, #2 cart; 54" Haban blade; Brinly box blade, 48" dethatcher, moldboard plow; Agri-Fab sweeper 1200, 1863, 1864 parts machines |
Just as was discussed above, some Series II had a block off plate, some didn't.
Josh Diesel Cub Cadets........... |
I was asking if series IIs started before MTD began production, (as in all MTD built units were built with series IIs) or at least that's what I meant. I was trying to figure out if it may have had an engine swap.
