Old 05-17-2014, 08:56 AM
dbuck dbuck is offline
Smile 149 hydraulics ?.
When mowing, I noticed that the deck was inching down. So after mowing, cleaned it up and put in the shop with the deck up. Next morning the deck had leaked down and was sitting on the shop floor. Anyone have any ideas/suggestions on what maybe going on? If so, any ideas/suggestions how to cure this problem? Thank you for your time.
Old 05-17-2014, 09:22 AM
84Buckeye 84Buckeye is offline
Actually I'm very curious what you get with this on here. My deck stays up fine mowing, but when its turned off it lowers down. I just pull it up when I start it up again, thought this was normal.
Old 05-17-2014, 09:39 AM
That's normal, don't worry about it.
Old 05-17-2014, 09:42 AM
Finding the deck lowered the next morning is normal. The hydraulics will bleed off. To keep your deck at a constant mowing height set your deck height and use the cam to limit the rockshaft from moving and letting the deck move lower.
Red lines showing cam stop assembly.
Old 05-18-2014, 09:20 AM
Smile
Thank you Guys for your replies. I re-set the cam and see what happens. Buckeye, what part of Ohio are you from?
Old 05-18-2014, 05:44 PM
Pretty much the center of the state dbuck.. Mid between Canton and Mansfield.
Old 05-19-2014, 09:01 AM
Smile
Thank you for your reply. I was born and raised in Jackson, SE corner of the state.
