Old 05-18-2014, 09:17 AM
DarwinsFlinch's Avatar
DarwinsFlinch DarwinsFlinch is offline
Default Fender Dents - I Don't Do Body Work...
Is there a quick and dirty way to smooth this out a bit? (clickable image)
Old 05-18-2014, 09:25 AM
dbuck dbuck is offline
Smile
That should be easy, with a dolly and body hammer.
Old 05-18-2014, 09:28 AM
Never done a bit of body work.. again in english?
I've used an adjustable wrench to straighten them. They won't be perfect but pretty close.
Old 05-18-2014, 10:12 AM
You need two hammers, one for bottom one for top...the bottom one you hold against the top one you swing lightly and methodically...its all about how you place the bottom hammer during the swings...try it, off to one side or the other, youll get a feel for it...a dolly makes up for the bottom hammer, but for a spot you can get to so easy two hammers works better....little 2k primer, little fine filler, and youll have her straight as an arrow.....
Old 05-18-2014, 11:16 AM
Everybody begins at some point or other, so you can too! Have at it and see what happens--you will be surprised at what you can do if you first try. If you make a mistake, you can try at it again until you get it to your satisfaction.
Old 05-18-2014, 01:32 PM
That metal looks like it is stretched. If it is, you'll have to shrink it back with a shrinking hammer and body dolly the file it smooth. You can use heat too but I don't want to have to describe that process in writing.
Old 05-18-2014, 04:19 PM
TheSaturnV's Avatar
The trailing edge of my 147 fenders looked about like that. Stand them up on a 2x4 and prop the tops against a wall or something. Adjust the angle until the back slope of the fender edges lays flat on the 2x4. Get a ball peen or smooth head hammer and pound the waves out. The ground and 2x4 gives a great surface to work against. Light taps, work up and down the trailing edge. Mine came out very straight.
Check the restoration link below, I think I included a shot of me doing this in the intro to video #1.
Old 05-18-2014, 04:29 PM
TheSaturnV's Avatar
Check the restoration link below, at 1:35 there is a short clip of me doing this:
https://www.youtube.com/watch?v=_FhmC8Mk9Lw
