Old 05-04-2014, 05:27 PM
TIMCRUTCHER TIMCRUTCHER is offline
Default Rear pto
Will a farmall cub rear pto work on a cub cadet?
I don't use my Cub. I just work on it and look at it. So far it's holding up very well.
Old 05-04-2014, 05:36 PM
I believe it will.
Old 05-04-2014, 06:59 PM
I hate to go with just a believe. Anyone know?
Old 05-04-2014, 07:25 PM
What are you putting it on?
This was discussed before, do search on the forum "rear pto."
Up to 530 and counting...
Old 05-04-2014, 08:06 PM
Will do
Old 05-04-2014, 08:23 PM
Yes, the parts will all bolt right in. BUT you are still going to need the top transmission shaft. (Which is impossible to find alone.) Plus, there is a cut out on the CC PTO bearing plate for the rear check plug. If you are going to use the entire unit off of a cub, there will be no check plug for the oil level. On the older tractors like a 71 the control linkage will work also.
