Old 03-16-2014, 07:31 PM
Pequeacubs's Avatar
Pequeacubs Pequeacubs is offline
Question Help please with #1A tiller
hey guys this is my first post. I have some question about the mule drive pulley. I know the manuals says to replace them with solid steel pulleys but can't seem to locate any after market it ones with bearings. can u still run the stamped steel ones? any help is much appreciated thank you
107 w/ 75lb IHC wheel weights 3pt. hitch spring assist lift.
1810 w/spring assist and brinly cat.0 3pt hitch w/A frame adapter and sleeve hitch now an 1811 cab and 551 blower
1000
42" spring tip snow dozer blade,qa36a snow thrower,#1 tiller w/1 ext., brinly 10"moldbord, 3pt.cutivator,brinly disk,#1 trailer #4 trailer, 2 sets of Ih weights
windbreaker soft cab,qa42" snow thrower
my grand fathers 67' j.d.110h with brass tag 6 way snow/dozer blade
67' WH lawn ranger
Old 03-16-2014, 07:33 PM
Welcome to OCC
I got deeper V pulleys at NAPA and they worked well on my 125 with my 1A tiller.
Jeff
Found my post with the numbers
http://www.onlycubcadets.net/forum/s...&postcount=193
The NAPA pulleys, part # 7-05212 , are deeper and wider than the original (NF) pulleys.
Original NF pulleys .460 wide and .520 deep
NAPA pulleys .563 wide and .550 deep
The person who let me know about the NAPA tiller belt for the NF ( AX-144 ) told me to use those pulleys to keep the long tiller belt in place.
It worked great for me and haven't had any issues at all using the factory belt on my mower deck.
Jeff
Old 03-16-2014, 08:19 PM
Pequeacubs's Avatar
Welcome to OCC
Jeff
Jeff
Thanks Jeff that is really helpful
1000
67' WH lawn ranger
Old 03-16-2014, 08:21 PM
Can you still run the stamped steel ones? any help is much appreciated
This is what happens...
Old 03-16-2014, 08:26 PM
Pequeacubs's Avatar
Yikes doesn't look like that day was fun.
1000
67' WH lawn ranger
Old 03-16-2014, 09:43 PM
Welcome to OCC!
Old 03-17-2014, 12:49 AM
Welcome to OCC!
Old 03-20-2014, 12:50 AM
Pequeacubs's Avatar
hey Jeff thanks for the napa pn's they should be arriving t/m
1000
67' WH lawn ranger
Old 03-20-2014, 08:44 AM
I've seen some stamped pulleys that have a bead of weld around them in the bottom of the groove and they hold up.
You might get by with a spot welded pulley, but only on the slack side, not the power side.
Just remember when they split/break, it usually chunks the belt too so you have added cost.
Old 03-20-2014, 02:08 PM
Pequeacubs's Avatar
Jeff in pa would you happen to have any pics of your mule drive set up with the napa pulleys?
1000
67' WH lawn ranger
