Old 03-30-2014, 04:50 PM
gmbadgley gmbadgley is offline
Default How many hours on your cub?
The reason I ask is, I just cleaned the face of my hour meter on my 1450 with 800 wet paper & polishing compound so I could actually read it. It shows 135 (yes it is working) but since I bought the machine last year I have no idea what the actual hours are. I would bet that it has been around at least once so that would make 735 total.
She runs fine, no drive problems so I guess to me it is just a number. Now that I can read the clock I will have something to go on for PM services.
Just wondering what others had for hours on their machines.
Greg
"If I can't fix it, I can screw it up so bad no one else can either"
Old 03-30-2014, 07:24 PM
jimbob200521's Avatar
I've got a 1450 with unknown hours but it's certainly been run around the block once or twice. After a little TLC, she's running strong again ready to till and mow up this year then push some snow next winter. I've also got a 1050 with, again, unknown hours and it's just starting to smoke but honestly, it starts on a dime every time. And finally, my 1811 has about 81x hours on it and running great (finally, don't ask). There's others here with thousands of hours on motors that went and are still going strong, it's honestly all about maintenance; oil changes, spark plugs, points, carb cleanings, etc. Take care of them, and they'll take care of you
-Ryan
Old 03-30-2014, 08:28 PM
Don't know how many the 782 has. My 1872 has a little over 1200 hours.
Old 03-30-2014, 08:43 PM
john hall's Avatar
My 982 would have had to lap the clock at least once given the wear I am finding. My 2072 has some over 900 hours. I did run across a 1282 recently with over 4000 hours, I still don't believe it and I looked at it twice. If they are real hours the machine was used but not abused. The guy wanted $700 for it and it wouldn't run, I expect he'll be keeping it a while longer.
As for maintenance, we don't go by hours but by the calendar. We don't use them for severe duty or commercially. We change oil once or twice a year and change hydro filter at the beginning of the season. Grease it a couple times a year unless something on the deck needs it more often. Clean and replace the air filter as needed based on the conditions you are cutting, same for the blades. Everything else inspect and repair as needed.
Old 03-31-2014, 02:28 PM
amy3588's Avatar
amy3588 amy3588 is offline
I dont have an hr meter but I know it has more hours on it than me.....
wait...that didnt sound right
Nothing runs like a Deere with a Cub on its tail !
Old 03-31-2014, 06:37 PM
MinnesotaCadet's Avatar
My 1250 had 3,651 and 6 seconds on it before I started parting it out. No joke.
Connor
Old 03-31-2014, 06:54 PM
The clock style hour meters don't read in "seconds". Only hours. The little white hand only indicates the meter is working.
My 1811 has around 1850 Hrs on it. Second motor installed at 1175 HRS. Rest: unkown. Replacement meters or don't have one.
Old 03-31-2014, 07:22 PM
Yes they do
Up to 530 and counting...
Old 04-01-2014, 08:30 PM
IHCadetCollector's Avatar
IHCadetCollector IHCadetCollector is offline
1979 1200 with 1580 HRS all original, with 1 engine rebuild that included sleeving the cylinder.
I lost track of what I own a long time ago!
Forgot photo.
