Old 01-25-2014, 01:42 PM
Flatbedford's Avatar
Default WF hydro driveshaft ques
The hole for the drive pin on my 149s is worn and the pin is falling out. Jeff in Pa can make a new one for me but he needs measurements. I have a 1/4" Nut and bolt in there now and don't want to take the tractor out of service until I have a replacement. Can somebody provide pictures with measurements of a WF hydro shaft?
I do have a worn 125 shaft. Are the NF shafts interchangeable with WF shafts? Can I use measurements from the 125 shaft?
Thanks
Steve,
Former multiple 149 owner.
Old 01-25-2014, 01:57 PM
I just realized that everything we need to know is in this thread. http://www.onlycubcadets.net/forum/s...ad.php?t=28148
Any additional comments are welcome though.
Steve,
Dave R Dave R is offline
Default 149 drive pin
The pin in mine was replaced with a bolt when I got it. After a few months that sheared and it fell out. I replaced it with a pin, however, I am tempted to go with a bolt if it falls out.
I just won't tell anyone.
Old 01-25-2014, 02:05 PM
My first bolt only lasted one snow storm. The second is a grade 5 and may last longer. The correct pin is way harder stuff than any 1/4" bolt. While replacing the the lost pin or broken bolt is fairly quick and easy it is a real PIA, especially when it breaks at the neighbor's house during a snow storm. I want to get the right stuff back in ASAP.
I bought a 125 that had a brass hinge pin in there! It lasted a surprisingly long time.
Steve,
Old 01-25-2014, 02:12 PM
Mlohss's Avatar
Mlohss Mlohss is offline
The pin is currently falling out of my driveshaft, so I also put a bolt in my 149. It lasted all mowing season and 4 snowstorms now. I want to change out the driveshaft, as I replaced this one 5 - 6 years ago, and have already had the pin fly out (yes I am a little hard on it). I was considering changing to the Quietline driveshaft, as I have a lot less trouble with these. Did anyone do a "step by step" on this site for the switch out? I am curious if everyone uses the self aligning bearing at the front, and also installs the little ball between the input shaft and the driveshaft.
Old 01-25-2014, 02:43 PM
Muzzy Muzzy is offline
I had the same problem with one of my tractors so I got a pin 1/2" longer and put a spot of weld on each end of the pin so it could'nt slip out. It was intended to be a temporary repair but, 2 years later and alot of use it's still holding up.
Old 01-25-2014, 05:16 PM
Merk Merk is offline
I use a hose clamp on my 149.
Project Uncle Dick
Cub Cadet 70
Old 01-25-2014, 08:14 PM
I have yet to have that problem with a hydro pin flying out after replacing it.most of the ones I use are rusty from sitting out.
Old 01-25-2014, 08:25 PM
A single well placed centerpunch mark works wonders
Old 01-25-2014, 08:30 PM
How you making out on the driveshafts for the n&w frames?
