Old 11-08-2013, 06:18 PM
Po-Boy's Avatar
Po-Boy Po-Boy is offline
Default Steel seat on a 102...
Anybody here ever mount an old steel seat pan on a narrow frame 10X series? I know the sheet metal would present some challenges, just curious if anyone had pics? I have this 102 and want to do a "phantom" version w/ ags on the rear, 3 ribs on the front, Allis Chalmers orange paint, 1947 Farmall Cub decals, and a steel pan seat. Call me crazy, but there's no real collector value to the 102, and just want something unique to putt around shows or the occasional parade when not plowing snow or hauling yard debris, etc.
Old 11-08-2013, 07:49 PM
jonjunk's Avatar
jonjunk jonjunk is offline
I tried to with my 122, bought the seat mount for a 71 figured out it will not fit because if you look at the 71 and 102 or 122 the 71 has the lower tunnel compared to the 122 or 102 so I could not fit thr factory 71 seat mount but if you were to find a 71 and drop in your 10 hp it would be a low tunnel 102 with a pan seat already on it, square fenders would not fit though.
122 PTO, lift, deck, weights, and chains clist pick
123 headlights no motor came with the 122
Stx38 free acquisition but its the wrong color works great though
Free craftsman gt 17hp Briggs Intek hydro
Old 11-08-2013, 08:41 PM
I don't think you should have a stolen seat on any cub--buy your own and put it on! Oh, wait, you said steel seat....not steal a seat. Ok, in that case, you could buy a seat that a puller uses. I think they are aluminum. It isn't a pan seat, but often a flat seat that will allow you slide from side to side and shift your weight. Like this one: http://www.ebay.com/itm/CUB-CADET-JO...item19e46fc2a7
BTW: I like your white air cleaner assembly on your 102. Is that factory colors on it?
Old 11-08-2013, 10:08 PM
Po-Boy's Avatar
Thanks for the feedback gentlemen. I'm sure the Cub spring mount wouldn't work for exactly the reasons jonjunk pointed out. I thought about the "puller" pans and covering in a hand tooled leather, as I do chopper seats as a side business, and have everything I'd need material wise http://www.po-boybikeworks.com/default.html. I think I'd rather figure out a way to low mount an old type pan using the existing sheet metal configuration. I also work for a company that makes outdoor furniture cushions, so maybe I could emulate the old John Deere B model seat style, only smaller, and cover in vinyl?
Old 11-08-2013, 10:11 PM
Po-Boy's Avatar
The guy I bought it from has thirty some restored Cub Cadets, everything from a pristine O to the newer stuff, so I'm sure it was the correct paint code, as he has painted many over the years! LOL An amazing collection IMHO...
Old 11-09-2013, 01:36 AM
jonjunk's Avatar
You do great work with leather I am impressed!
If you find a decent way to mount the seat with the square fenders left on let me know. I was going to try one ither thing, the seat mounting part I mentioned is the same shape as the top of the tunnel in my 122 it could probabaly be made to fit under the tunnel it has but I would have the 3 point I will see if I can make it fit into my 123 but I would for sure have to cut or ditch that sheet metal piece on back to make room for the spring (the one with the IH logo) I believe I have seen a picture of one this style with the pan seat and spring but from a front view so they made something for the spring, or just made it work.
Old 11-09-2013, 06:21 AM
someone used 127 seat springs on my 123, i just found a seat pan base for it at the junkyard tuesday.
Old 11-09-2013, 07:36 AM
Po-Boy's Avatar
Thank you for the compliment! I'm already missing that piece, so I though about that as well. Would have to mount the spring under the sheet metal and come around and over the seat base that connects the fenders, if that makes sense?
Old 11-09-2013, 07:37 AM
Po-Boy's Avatar
Post some pics when ya get her done. That sounds like it would work...
Old 11-12-2013, 02:04 AM
jonjunk's Avatar
anyone else ever mount a pan seat on a high tunnel?
