I picked up this 124 with a belly mounted scrape blade last fall. I don't know why I bought it, it just happened.
![]() ![]() Tear down was pretty straight forward. Pulled the hood and grill and then started on the PTO. There was only 1 set screw in each hole. As far as removing the PTO, dad had me grab a tire tool and set in the bottom of the "V" and give it a couple whacks with an adequately sized hammer. Maybe 5 hits and it was off. As the pics will show, somebody had been in here before---Notice the setscrew that was drilled out into the crank, brazed pulley, etc. Now before I go any further, lets get one thing straight. After 30 years in a machine shop I understand that the crank NEEDS to have a new key machined and that the pulley needs heroics or replacing. Likewise the crank needs to be turned down and pulley compensated, or flame spraying on the shaft to fix the wear. IT AIN'T GOING TO HAPPEN. This is just a toy, not a money pit. In other words, this is going to be a low budget patch job, that will last forever for the 1 or 2 hours a year this thing may get ran. I've seen guys here before have bad key slots in the crankshaft. I cleaned off any buggers with a file and made a longer key. Great idea until my dad pointed out the locking collar would hit it. So I milled a step in it that will allow the collar to go right over top of it. As I mentioned the shaft shows wear (couldn't really feel it but I could measure it). Also the pulley had wear in the bore--again I measured it to know what I was dealing with. The new key fit really tight in the shaft (obviously in the unused area of the crank). I cut some shim stock to wrap around the worn area of the crank--I TOLD you this was going to be low budget, remember ![]() Here are a few pics to prove it happened. That's all for this installment.
Nothing wrong with a "minimalist" repair approach. It's like buying a tool at Harbor Freight--as long as you know the consequences of that decision, there is no shame in saving a few buck$.
I like the belly mounted blade. That should work well to level out a gravel drive. How about some details on how it is mounted?
Very nice work! It's nice to see this kind of repair. Not every tractor can be a money pit.
61 and 63 Originals 123 (2) 782D 106, 147, 122 102 parts It's only original ONCE!
I have a couple keyslots that look alot like that but they are on axle shafts, I dont have a 'good' complete transaxle but I think I found a good differential with usable axles, keyslots arent perfect so I may need to add shims but I think they will do the trick.
Lance / Alberta Can IH 127 w/deck, snowblade IH 154 Loboy(x2) w/creeper 3pt and 3160 deck CCC 12.5 w/deck Plus 35 or so non IH tractors |
Nothing wrong with your repairs if you are happy with the out come. That's all that matters. I've done similar "fixes" myself.
I would also like to see as much detail you could provide on the belly blade. I have been trying to find one without luck and may build one if I can get enough pictures etc. Would you consider selling the belly blade? Send me a pm if you might be interested.
149, 2072, Original, 1772, 1782, #1 cart, Parker 48" sweeper, |
I'll post some pics of the blade and its mounts. The blade is fairly nicely done but is all homemade. We used it a little when I first got it, but it didn't seem to "float" like it should. I'll look it over and see if there is anything not functioning properly, or if it is just bad design keeping it from floating.
Shoot John, looks like a good "shade tree mechanic" fix if there ever was.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
I made the exact same repair to the crank on my 108 and then used it to mow grass for 5yrs with a 48" deck, still no issues and the basket pulley is tight.
If/when adding shims to the keystock you can add a few tiny drops of JBweld in between the shim and the key, that helps fill any irregularities and sticks the shim to the key permanently and in the correct spot in case you need to take it apart in the future.
Made some headway today. Put the PTO clutch back on--nothing to use it for but this way it won't get lost.
