Old 12-28-2009, 10:45 AM
OZCUB 123's Avatar
OZCUB 123 OZCUB 123 is offline
Default Idea for hydraulics
Hey guys, I am thinking of putting a PS pump on the cub for Aux hydraulics for a trailer dump etc not too fussed about the deck and blade. I was looking at the cub and there is a heap of space under the seat and a drive output from the rear of the hydro. So my idea is this mount the pump under the seat drive it from the hydro shaft and make a low profile tank, I have a spool valve handy mount it under there too (it'll fit I checked) with the handle facing forwards thru a hole in the guard and voila Stealth Hydraulics! I would mount the pump beside the engine but the pump would spin backward and on the other side it hits the aircleaner. Any thoughts, criticisms or idea's appreciated
Cheers Andrew
Proud owner of the oldest and only CC 123 Hydro in West Australia
Toys:'67 CC 123
42' blade & 48' deck to slow it down
Old 12-28-2009, 06:50 PM
I have been fooling around with the idea of using the "nub" on the back side of a hydro to run something, but "fooling around" is as far as I've gotten so far, not even sure what I would want to "run" yet.
As far as your p/s pump setting next to the engine, running backward goes, is it possible to turn the pump around and face it in the opposite direction?
Old 12-28-2009, 08:36 PM
OZCUB 123's Avatar
I did look at it but on one side it fouls on the S/G and the other it hits the air cleaner, plus I like the stealth idea:biggrin2.gif:
Toys:'67 CC 123
Old 12-28-2009, 08:40 PM
Cross the belt and have it face the other direction.
Old 12-28-2009, 10:40 PM
john k's Avatar
john k john k is offline
696 are you and ozfarm going to take over the occ site also. as for the hyd. pump is it possible to mount it under the hood just above the drive shaft? thanks john (52md).
Old 12-28-2009, 10:45 PM
Every PS pump I have seen has been way too big for that, unfortunately.
Old 12-29-2009, 01:15 AM
DougK109 DougK109 is offline
Some newer vehicles have small steering pump with remote reservoir, maybe that would be small enough?
Old 12-29-2009, 09:28 AM
OZCUB 123's Avatar
shhhh John you'll tell everyone our plan to take over the world.... one forum at a time:biggrin2.gif: as for the pump too big to go between battery and fuel tank
Toys:'67 CC 123
Old 12-29-2009, 09:31 AM
OZCUB 123's Avatar
maybe but im trying to use the pump I have
Toys:'67 CC 123
