Old 12-24-2009, 04:03 PM
electricmonster's Avatar
electricmonster electricmonster is offline
Default Power Angle
Does anyone know the spec's for the hydraulic ram for a 42" blade? I am looking to use a heavy duty electric linear actuator to make a power angle setup. I am waiting for the postman to deliver the OEM power angle mounting brackets. I would like to know the compressed and extended lengths of the hydraulic ram as well as the mounting eye hole diameters.
Has anyone tried this? I would love to add a hydraulic pup and lift setup to my 127. Alas, I can't find one anywhere. Any ideas on sources? I look constantly at the parts vendors listed on the site as well a E-bay.
I saw an old post looking for the same info. Nobody responded.
Regards,
Mike
Old 12-25-2009, 12:03 PM
IHinIN IHinIN is offline
According to an add that was on eBay, the extended length is 21.5" and retracted length is 15.5" so it's a 6" stroke.
Old 12-25-2009, 01:54 PM
Merk Merk is offline
Mike,
You can replace your non ported hydro pump with a ported pump from a wide frame/quiet line Cub. You may have to do some fabrication to make the the spool valve, hydraulic cylinder, and lever to work on your cub. You wll need a dual spool valve to lift and control the blade angle on your blade.
There has been a few narrow frame hydro Cubs with a single spool valve at plow days.
The factory hydraulic system for a narow frame cub has only a single valve set up in it.
Old 12-26-2009, 10:15 PM
wig wig is offline
You will not be happy with the speed of a linear actuator and the cost of them will scare you. You would be best off buying the real thing. I have one forsale.
Old 12-26-2009, 11:23 PM
Sawman Sawman is offline
Will a linear actuator take the abuse ? These Cubs push hard and don't stop when you hit something. Watch your local paper for a cheap tractor, mower or whatever with hydraulic lift then you get a cylinder and valve and sometimes a pump, this is what I came up with for $100.00, valve with float and a 1" cylinder with a 4" stroke, plus a whole tractor to part out (a red horsey tractor) I was lucky enough to have a pump laying around, my hydro pump runs the lift and the add on pump runs the angle.
