Old 03-24-2013, 09:14 AM
smitty88 smitty88 is offline
Question cub cadet 2166 wont start
2166 cub cadet with 16 hp kohler horizontal shaft will not start. getting gas & has spark. i checked all fuses and wires all look good, also changed key switch. the only way it will start is if i hold the key in starting position amd remove solenoid wire as it starts to disengage the starter. if i try to release parking brake or turn pto on it dies... any ideas???
Old 03-24-2013, 10:51 AM
Sam Mac Sam Mac is online now
I don't have the wiring diagram for a 2166 but it sounds like a safety switch or connection problem to me. Take a good look at the seat switch first.
Old 03-24-2013, 12:38 PM
thank you for your suggestions...i checked all safety switches they all are operating correctly.. i also checked and cleaned all connections....it still wont start...
Old 03-24-2013, 01:55 PM
Sent you an e-mail
Old 03-24-2013, 05:25 PM
Sent you everything I could think may help. Keep us posted.
Old 03-24-2013, 07:07 PM
thanks for all the info. its not exactly the same, the wire colors are different but im thinking it might be one of the relays or a diode. but really not sure cause it will run as long as i hold the key in starting position.
Old 03-25-2013, 11:17 AM
You mention that you changed the key switch, did you get the proper one from a Cub dealer? Most of the stuff you pick up at TSC etc won't work on a Cub.
Old 03-25-2013, 04:50 PM
yes i did go to dealer for the new switch..tsc didnt have anything close
Old 03-25-2013, 05:08 PM
Sounds like test light time, a copy of the Kohler manual, a cold beer and a cigar.
Old 03-25-2013, 05:15 PM
amen on the cold beer that solves all problems!!!!!!lol
