Old 04-07-2013, 05:26 PM
sawdustdad's Avatar
Default Erratic mowing speed-hydro tractor
I was testing out my 1650 mowing some grass today. My yard is hilly, so going uphill and downhill, the speed varies A LOT. Also, it would not "back" up the hill. new fluid, new filter. Backs on level ground. cutting grass I have to give it more hydro lever to get up the hill, then it's way too fast coming back down. So I am constantly having to change speeds. Is this bad relief valves?
Old 04-07-2013, 06:44 PM
There is only one solution, and it is not relief valves.
Gear drive!!
I really like Cub Cadets, but, a hydro will fail on a grade.
I offered to buy a 430 JD brand new if it would go up and down my yard without constantly readjusting the hydro control. The dealer said no problem.
This really isn't that steep.
The 430 failed. The dealer said the 430 must need adjustment, that he would be back.
I am still waiting, that has been over 10 years!!
Old 04-07-2013, 06:55 PM
It is part of the Hydro deal get used to it or get a gear drive. I run with one hand on the hydro all the time.
Old 04-07-2013, 07:37 PM
I enjoy riding with one hand on the hydro, not a problem for me.
Could be your trunnion is worn.
Old 04-07-2013, 08:04 PM
Muzzy Muzzy is offline
I think the trunion is probably worn too but, driving with your hand on the hydro is normal to me too.
Old 04-07-2013, 08:05 PM
sawdustdad's Avatar
So why won't it back uphill? (go backwards uphill).
Old 04-07-2013, 08:10 PM
You may have a bad relief valve.Switch em' and see it that helps.
Old 04-07-2013, 08:27 PM
LawnMowerMan's Avatar
LawnMowerMan LawnMowerMan is offline
Default 1450 too?
Will I have this hydro problem with my 1450?
Old 04-07-2013, 08:30 PM
Yep!
Old 04-07-2013, 08:37 PM
Default 1450 hydro issues
Yae, thats a relief. :-I
