Old 06-13-2012, 08:34 AM
vargafarm vargafarm is offline
Default 1450 Governor
Hey all.
I picked up up a 1450 last year in pretty good shape but in need of some TLC.
I haven't really done anything other than a little tuneup and run it.
Anyway, my I was cutting with it the other day when it started revving up too high. The only way I was able to maintain a reasonable RPM was to use 1/4 throttle.
Any thoughts?
thanks
Old 06-13-2012, 10:49 AM
Originally Posted by vargafarm View Post
Hey all.
Any thoughts?
thanks
Sounds like the gov needs to be reset, or it's broken.
Here's a link to the service manual
http://www.onlycubcadets.net/forum/s...ead.php?t=4646
And the link to the owners manual
http://www.onlycubcadets.net/forum/s...ead.php?t=4647
Old 06-13-2012, 01:59 PM
well, nothing seems loose, and I have not made any adjustments, so
I am going to assume something is broken at this point.
A governor is one of the things I have never gone into, guess that will change pretty soon.
Old 06-13-2012, 02:02 PM
Peruvian Peruvian is offline
I've got the same problem on my 1450. I honestly haven't had time to deal with it and have controlled the RPMs with the throttle over the last several uses. You will find a serious loss of power when going up hills or using the PTO with this method and obviously the governor needs to be repaired and I suspect the flyweights are shot. Unfortunately the manual only explains how to adjust it but not how to repair it (I assume it involves removing the head, but I'm not a real mechanic!).
Old 06-13-2012, 02:20 PM
I have never had problems with flyweights,
but, I am a big guy!!
Couldn't resist!! I guess I need a
Old 06-14-2012, 09:41 AM
Ash_129 Ash_129 is offline
Unfortunately, the governor is one of the first parts put into the engine during assembly.
Cub Cadet 129
48" deck - grass mowing
38" deck - backup deck
42" front blade
Old 06-14-2012, 09:52 AM
yeah, I hadn't investigated it much further but figured that would be the case. Oh well, it is burning a little oil so I might as well go through it while I am at it, and replace the iso biscuits, and weld the cradle while it is out.
Is there any potential for the governor to catastrophically self destruct if I run it carefully?
Old 06-14-2012, 10:00 AM
There is a chance to come apart or have a broken part get in a place where it shouldn't be.
Old 06-14-2012, 05:09 PM
If the governor suddenly stopped working, it's very likely there's already pieces floating around in there, so I would not run it anymore until you fix it.
Old 03-31-2013, 01:09 PM
found the problem.
the paddle broke off of the governor shaft
never would have thought that would happen, but shows anything is possible.
