Old 04-03-2013, 01:45 PM
vartz04 vartz04 is offline
Default Removal and Re installation of 3 pin driver pushing?
Does this need to be pressed in/pressed out? Just trying to figure out if I need to take this over to my dads to use his shop press or if i can knock it out at home. This is for a 104
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 04-03-2013, 03:05 PM
sawdustdad's Avatar
Mine came out quite easily. find a socket from your socket set that is just a hair smaller than the driver disk bore, place it over the bushing and give it a tap. Should come right out.
Old 04-03-2013, 03:12 PM
Thats what I was thinking while I was sitting here at work. Good to know that that should work. Getting the new one in should be just as easy?
Old 04-03-2013, 03:28 PM
sawdustdad's Avatar
yes. should go in easily. Mine was snug but not difficult to remove/install.
Old 04-03-2013, 05:00 PM
PaulS's Avatar
PaulS PaulS is offline
Same here on a 3 pin driver on our 102. It is snug but not very hard to tap out.
