Old 03-20-2013, 10:50 AM
vartz04 vartz04 is offline
Default Missing grill retainer screen tab
Guys,
one of the tabs that is used to hold the grill screen onto the cast iron grill is broken off of my tractor. My first thought was to weld a tab on since its weight bearing capacity wont matter its just gotta hold a 1/2 lb grill.
Any other ideas?
Cub 104 Refurbed Sprinig of 2013
Aftermarket headlights, 3 point, Brinly Adapter, Spring Assist, 42" IH Blade, 42" Mower Deck, 42" Craftsman Grader Blade, 10" Brinly Plow, 6-12 ags and 22x9.50 turfs
Old 03-20-2013, 10:54 AM
Weld! Weld!!
Old 03-20-2013, 11:11 AM
You make NO mention of the Model of tractor you are working on.
Old 03-20-2013, 11:12 AM
sorry 104, i put it in my sig but i guess some of you guys have a 100 of these things.
Old 03-20-2013, 11:21 AM
Muzzy Muzzy is offline
How about some JB weld?
Old 03-20-2013, 11:23 AM
jb weld would probably work. I have a welder though so I figure that would work as good if not better than jb weld and I don't need to buy anything. I know welding cast iron usually doesnt work but thats more for weight bearing stuff. for just the grill screen a little wire from the mig should hold it.
Old 03-20-2013, 12:23 PM
We learned a long time ago, what one is working is NOT necessarily what is in one's signature.
Old 03-20-2013, 06:46 PM
Cast Iron can be brazed or stick welded with nickel rod or a cast iron rod that contains nickel.
a normal wire welder using regular wire will not stick sufficiently.
