Hi All, Im coming to the experts again with a question. I have an easy starting, perfectly running motor, for 10-15 minutes. Then it coughs & sputters & stalls out. It continues to do so until I let it cool. I can still easily rotate the motor by hand, even immediately after it stalls. - The gas & tank is clean, I even swapped out the carb with a known good one; still the same problem. I purchased this 122 from someone, so I dont know the history behind it.
Any thoughts? Brian
Restoration project: 124 with Danco Loader My father purchased this new
![]() It could be a lot of things, but it sounds like it has something to do with heat. You may want to check the Timing.
Im reading the service manual now on how to do that... I didn't realize that heat could have anything to do with timing.
Check the Coil. Sounds like it is going bad on you.
Here is the coil link and how to trouble shoot it: http://www.onlycubcadets.net/forum/showthread.php?t=11 Just like in a car, if the timing is out then your cylinder isn't firing correctly and could be causing an increase in heat. Here is a link on setting your timing. Probably wouldn't hurt a thing just to check it. http://mgonitzke.net16.net/tools/static_timing.pdf
You have to determine is it's a fuel or spark problem. Also common for an exhaust valve starting to seize.
Thanks for the info, DX3, I can't get that link to open on setting the timing, does it live somewhere else? I hope it's not the exhaust valve seizing.....
BP
Coil or condenser will do that when they heat up.
I think DX3 hit the nail on the head with the coil. My 125 had the exact same symptoms last summer. It would run 15-20 minutes start skipping and sputtering and eventually just die. I replaced the coil and runs like a champ now.
149,682,1641,1711 with a 12hp in it 1 8" brinly plow 1 10" brinly plow 451 snow blower,H-48 International snow thrower 42" york rake with fold down grader blade. |
Yeah, the link is on a members website. It came up for me. Its a PDF file. If you look into the Tractor Tech Library that we have, there is also another link for how to do the timing. But I honestly think you have a coil issue. If you replace the coil, I would do the whole setup and replace the points and condenser all at the same time and be fresh.
agreed with the above statement. good luck
CC 123 402c Sickle Bar, 48" Mower Deck QA42A Snow Thrower, 42'' Push Blade IH Back Blade and Rake Brinly Seeder/Aerator Brinly Lawn Rake Brinly 10" Moldboard,Brinly Cultivator, Brinly Disc |
| Tags |
| engine, kohler, stalls |
