Old 02-25-2013, 04:39 PM
sawdustdad's Avatar
Default Retro-fitting a Rear PTO
I see from time to time a rear PTO on ebay. Like this one:
http://www.ebay.com/itm/CUB-CADET-RE...item4170e9366e
Ignoring the price, how difficult would this be to install?
Old 02-25-2013, 04:55 PM
bolivier's Avatar
bolivier bolivier is offline
How cool would that be? What do you plan on running with that if you were to ever get one?
Brent
Old 02-25-2013, 05:13 PM
ssechrist ssechrist is offline
Price doesn't seem to bad, I think it'd be pretty awesome!!
Old 02-25-2013, 11:00 PM
Jumper Jumper is offline
The rear PTO's are pretty cool but they turn in the wrong direction, so you have to get one of those Hub City reverser's for about $400.00 to $500.00 bucks (picture 1) and you can run standard 500 rpm equipment. Other guy's have found or built equipment to use them as they are.
Old 02-26-2013, 06:52 AM
There only value, as mentioned above, is the "Cool Factor". Functionally, they are worthless, as is.
Old 02-26-2013, 07:15 AM
sawdustdad's Avatar
So, back to my original question. How difficult is it to install one on an existing tractor? Does it require complete dis-assembly of the rear end, or is it simply installed by removal of the rear cover? Anybody know?
That one on ebay sold for $360.
Old 02-26-2013, 08:21 AM
Here ya go..... Installation Manual
Old 02-26-2013, 10:52 AM
Shaner Shaner is offline
if it makes it any cheaper for you....find a rear end out of a cub loboy or farmall A or cub. they will work. just need to put your axle tubes from your cub on them.
Old 02-26-2013, 11:00 AM
There is a lot more to it than that.
red56turbo's Avatar
In order to install them, you have to swap out the shaft in the tranny to accept the PTO. There is a collar that slides back and forth to engage the PTO. The stock shaft doesn't work with the PTO. So the tranny has to come apart. Not too hard, just takes a little while.
Josh
Diesel Cub Cadets...........
