Old 02-23-2013, 12:05 PM
jeff k.'s Avatar
jeff k. jeff k. is offline
Question Velocity stack installation ?
Just wondering,Do u have to remove the choke butterfly when u put a velocity stack on? looks like the lever on the out side gets in the way. If u remove it how dose it start w/o choke. I plan to cover it w a filter. Do i have to pull the filter to choke it every time?
cub cadets : orignal w/ mower,orignal w/ push blade, orignal w/BB-36 snow thrower,72w/creeper,100, spirit of 76,76,55, 95 Electric,107,2-125 ,Johnson TC-10 loader, ,127,149,1100,282,382 hydro,382,482,2-IH 582,682 w/ spring blade,2-782,782D,1282,982,1782 super, and ,2-custom built 582 puller,2-narrow frame pullers,and 1-stock 582 puller
Old 02-23-2013, 04:08 PM
Pigpuller Pigpuller is offline
Smile choke
most carb builders take out choke butterfly . they claim it reduces airflow. in normal air temp. above 60 degrees. if carb is set up right you do not need a choke to start your motor anyway. with that said my 14hp stock tractor is a bear to start in cooler weather. i just loosen my filter clamp pop air filter off and put my palm of hand over it. it starts easily .than i put filter back on it only takes a minute.
Old 02-23-2013, 09:28 PM
dvogtvpe's Avatar
dvogtvpe dvogtvpe is offline
you can also back the idle way down so the throttle plate acts as a choke . difficult if you have to have a dead mans throttle
