I was just curious if anyone has any advice on replacing the seals on the hydro pump? It looks as though the seals are leaking at the input shaft, front and back, and I don't know the name of the other shaft that the trunion is on but it looks as though both sides of it are wet as well. I can get a whole new (used)rear for 40$, just wondering if it would be easier to fix than swap. Thanks
![]() Quote:
Sometimes one leak over time can make it look like it's coming from numerous spots. If it was me, before going through a lot of extra work, I would remove the fender pan, and pressure wash everything around the rear and pump, and make for sure where the leak is coming from. Then you can isolate the leak and fix accordingly.
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
Maybe this will answer some of your questions.
http://www.onlycubcadets.net/forum/s...ad.php?t=21261 They are not all that hard to do. Download the service manual and read it. Holler if you have questions. ![]()
![]() Quote:
Sorry it to so long to update, it's deer season, anyway thanks for suggestions, it appears it maybe the cork gasket leaking not the seals. Thanks again.
Replacing the cork gasket requires the removal of the Hydro unit from the rear of the tractor. Those that I have replaced required moving the engine forward, removal of the driveshaft and brake connections along with the hydro controls. Then you can get to the hydro bolts and remove it. I would suggest that you determine if any of the other seals are leaking/seeping and replace them while the unit is out. A leak at the hydro is many times hard to find because of the hydro fan blowing the leakage all over the place. Replacing the cork gasket is a cheap job but a bit labor intensive.
With my son, EricR Super 2084 with 54" mower, 451 blower. 2086 with 3 pt hitch, 54 inch deck, 551 blower, 54 in brinly blade. A 4 digit original w deck. A 70 with deck. 2 102s both with 42 in decks, one with creeper, 1 36 inch IH snow thrower CW36, 1 42 inch IH blade. 149 with mower. 2072 w 3 pt hitch, Johnny bucket, 60 in mower, 451 blower. Jacobson GT 10 with mower. DR Lawn vac tow behind,Home made lawn roller. Brinly cart, 2 off brand carts and 1 home made cart. |
