This is my first time rebuilding a PTO clutch (for model 149). I followed the instructions in the service manual and I used the guage that came with the rebuild kit.
DSC_1160.jpg When I took the old PTO apart, it only had one spring plate. However, the kit came with two. So I put two. Is this okay? DSC_1165a.jpg I used the guage as instructed in the service manual. DSC_1167a.jpg Here's a shot of one of the inside springs. Does everything look okay with my reassembly?
Tractor #1--1972 Model 149 with rear lift Tractor #2--1972 Model 149 with rear lift 1A tiller w/both extensions, 38" & 42" Mower Decks, Wheel Weights, Ohio Steel Fabricators 10" mold board plow, two 42" snow blades, QA-42A Snow Thrower, Brinly Sleeve Hitch |
Looks right to me.
ditto what Lew said...
Tom 105, 149 w/44A, #2 & #4 carts 782 CCC Red w/44C 1512 Smoker w/50C, 450 Blower 2072 w/60" Haban IH/Lawnboy 3322 Pusher, Scag TT 61" JD 455, X495, Kubota 2150, Gravely 450, 812 |
Hi guys.
I am about to order the parts for the rebuild of my 149 PTO. It sounds like I have the same as what SharkyOhio found - one spring instead of two flat springs. I find it interesting we both may have what appears to be a non-stock setup on our 149 PTOs. I looked around and read somewhere that folks use the PTO rebuild kit (759-3490) which has one spring with the bent tips instead of the kit for the 149 (759-3489) because the double springs tend to slip (even with the spring retaining knobs that are on the 149 clutch pulley). Does this sound familiar? Is it a common practice to rebuild the 149 PTO with the single bent tip spring instead of the two flat springs? Is it nonsense? SharkyOhio - how did your PTO turn out? Thanks Vince N. |
Yup, I think it's good too. Two nuts on the backside, all threads showing approx same amount-- should work good.
I installed the PTO pictured above on my tractor, but I have not used it with a mowing deck or snow thrower yet. It seems to be working correctly with the release lever, but I always engage the clutch when I test drive the tractor with no deck or other implement attached.
I have not heard of the center spring plates slipping and the repair manual shows the two spring plate setup as the correct configuration for this type of PTO.
Looks good to me as well.
I have never had any trouble with the springs slipping. Nice work SharkyOhio ![]() |
ok, thanks guys, I will go ahead and get the 149 PTO rebuild kit
-Vince N. |
I installed the correct PTO rebuild kit for the 149 (the one with two flat springs) and it works great!
Now I will turn my attention to getting my 44" mower deck working better ... and be on the look out for wheel weights and snow blade. I love this CC...I even waxed it ![]() |
Make the best of each day , Todd ![]() Original's Face Lift thread.http://www.onlycubcadets.net/forum/s...ad.php?t=34439 (O) Start to Finish video.https://www.youtube.com/watch?v=GAoUNNiLwKs Wheel Around videohttps://www.youtube.com/watch?v=XUL-m6Bramk They can't all be turn key! ![]() |
