Old 08-12-2013, 02:11 PM
Shaner Shaner is offline
Default 7hp cub cadet question
I just looked at an Original Cub Cadet that is in pretty rough shape, but complete minus the hood emblem. It runs okay, but seems to want to run away. I have a question. The rod that runs from the governor arm to the throttle linkage on the carb, is it supposed to be in the top hole or the bottom hole on the governor arm?
Old 08-12-2013, 02:44 PM
cjrolke cjrolke is offline
i believe the top hole
check out one of the service manuals
Old 08-12-2013, 07:19 PM
The position of the governor spring is relative to governor control, or sensitivity. It doesn't affect speed. If the governor won't regulate speed, either the high idle isn't set correctly, or the governor is not working. By not working, that would include, binding or "sticky" throttle shaft or linkage, along with governor internal parts.
Old 08-12-2013, 08:41 PM
No springs on the linkage for the 7hp. Its a slightly different setup than the 10hps and up. The throttle cable attaches directly to the butterfly on the carb, and a solid rod runs over to the gov arm. I'm wondering if the position of that rod will effect the governors ability to work correctly
Old 08-12-2013, 08:49 PM
OOOOH that is not the way it is suppose to be,
Looks like this.The throttle is connected this way and the rod from the gov goes to the carb.
Old 08-13-2013, 12:29 AM
hmm i wonder if that could be my problem on this subject. ive had a wheel horse with the 8hp kohler that was set up like that
Old 08-13-2013, 01:04 AM
Yeah, if your throttle cable is going directly to the carburetor on a 7 or 8 hp Kohler, then your governor isn't doing anything at all.
