Guys,
Per the net-wisdom, I have been running MMO in my 1650- and it has been running better. With an unknown service history(as if there is ever a known history on a IH CC tractor?), would you still pull the head and clean it? I have removed the schroud and cleaned the fins. Michael |
If it was my tractor I would, the Kohler manual states that every 500 hours the head should be removed and cleaned, headgasket replaced, and inspected for wear and damage. That way you know that it has been done and won't have to worry about it for the next 10 years (or 500 hours, whatever comes first)
You can lightly mist some water in the intake while the engine is running about half throttle. The water will turn to steam when it hits the hot combustion chamber and the steam will blow the carbon out. Just don't mist enough to stall the engine.
If it was my tractor and it hasn't been using excessive oil, I probably wouldn't touch the head as long as the tractor ran well. |
WEll,
I pulled it off- bolts didn't seem that tight. NOT good- First time I changed the oil there was some metal, now I know running a clogged airfilter will washout the rings and score the cylinder wall. THe scores have polished so it's wavy around 2/3 - 1/2 the cylinder. Aluminum timing pin. Sounds like I have some parts to buy. Michael |
The bolts are only torqued to 25-30 ft lbs by the manual, so they aren't really that tight anyway. Keep us updated on your engine!
![]() Quote:
Yes, keep. Us. Posted. This is interesting for reference. Nik |
