Old 10-18-2012, 12:20 AM
Cub1450129 Cub1450129 is offline
Default 129 tunnel cover bolts
I am wondering what size bolts fit in the tunnel cover. The only thing thst I can find that will fit and thread in is an eye bolt from a turn buckle. I have been to 3 stores and cant find a bolt the same size and thread as the eye bolt.
Old 10-18-2012, 07:18 AM
I believe it is a 12-24 x 3/8" Hex head bolt - P/N: 710-3007
Old 10-18-2012, 10:58 AM
tractordude tractordude is offline
Drill out the hole and weld or jb weld a 1/4-20 nut under the frame. I have never had good luck with the little screws staying in the frame
Old 10-18-2012, 07:53 PM
Any well equipped Hardware Store will have a 12-24 x 3/8" bolt. There are at least three places locally here that care them.
Old 10-18-2012, 11:58 PM
I, too, have had a hard time finding them. My local NAPA (usually has what I need) didn't have them and they sent me to a specialty company called Fastenal and they didn't have any. So, I went to my cub dealer that had just 3 and each one was pricey....seems like it was over a dollar or two, which I thought was a bit much for such a little bolt.
Old 10-19-2012, 12:36 AM
JayJay JayJay is offline
Default Restore or Fix?
Cub1450129: I had a hard time STARTING the little bolts that came on my Model 149, and then I lost two of them in the grass; so I ran a 1/4"-20 tap through the rear two holes and used 1/2" long stainless steel bolts. I haven't had a problem with the setup, although I'm careful not to crank on them. I don't have the front bolts in the tractor at all, and I keep a 7/16" nut driver handy in the shed to pop the cover off.
Looking back though, I wish I had kept it original. I was using what I had on hand to "get'r done," now I don't have the option of "keeping it as it was."
Just something to consider.
Jeremiah
Old 10-19-2012, 01:48 AM
Jeremiah
Good advice, been there, done that
Old 10-19-2012, 09:28 AM
restore49 restore49 is offline
Fastenal Part Number -27630- pennies apiece 3/4 long.
Old 10-19-2012, 05:21 PM
Part of the problem is the original screws were self-tapping, so if the person installing them wasn't paying attention, they could be cross-threaded without it being noticed. Do that a couple times and there are no threads left. If the threads are still intact, make sure whatever screws you buy aren't self-tapping so you don't have to worry about this problem.
Old 10-19-2012, 06:13 PM
red56turbo's Avatar
Matt's right.
And then if they are cross threaded and the threads gone, the best option for me atleast is to tap them out bigger and use a bigger bolt. BTDT.
Josh
Diesel Cub Cadets...........
