Hey, you were right! The new Autolite #216 spark plug was junk!
![]() Went with your recomendation: Champion H10C and now the tractor is running like a saw! Thanks for all your help, BTW! ![]() ![]() p.s- These tractors cant be realy all that hard to fix, after all there are only a few things that need looked at, right? Because most of the time the motor just dont "untime" it's self!
IH CUB CADET 1450, 72, 86, 1211, IH #2 CART, IH 56" SNOW BLADE, COLLECTING CUB CADET ENGINES |
I'm glad you got it fixed John!
![]() I have used both autolites and Champions and have had issues with both so I don't recommend one over the other. |
I had autolite plugs in my Farmall B and it started wasn't running right so my uncle changed plugs and put champions in and then it started missing really bad. I put new points and condenser on it and it still did it. Finally I put the autolites back in and haven't had a problem since. I haven't found a consistant spark plug brand though. Every one I have tried seem to have there issues. It seems to me you just have to get lucky.
Adam Current Workhorses: 1977 1650, Sleeve hitch, #2 tiller; 1985 782, QA 42A snowblower, 50'' deck, 42'' blade, Ags, IH Wheel weights; 197? 1250; 1976 1250, hydraulic lift, 44'' deck, 54'' blade (currently needing a engine) Current Projects: 1970 107, Sleeve hitch, 42'' deck, Tri Ribs, 8'' Brinley Plow Family owns over 30 tractors, 7 combines, 2 bulldozers, 2 mid size trucks, 1 semi, too many truck and scouts to count including parts, and 3 pulling tractors. All vintage IH. |
Not to say Autolite brand is bad, I just happen to get a plug that seems to have went bad with in 7-8 hours run time. So we will wait and see what this Champion H10C will do. Funny, I pulled the Champion to replace with the Autolite.
I've used Champion and haven't had an issue, but I can relate to something being ok then it being crud.
