Old 09-12-2012, 12:38 PM
jcsmith jcsmith is offline
Question scratchin' paint
How does one keep the hood from scratching fresh paint on fuel tank on a 104. Surely every NF has this problem, right? Chris
1968 104 , service replacement '96 K301, 42" deck
1997 Scotts 42502X8 , repowered with '96 B&S 18hp TwinII , 42" deck
2007 LA130,21hp Intek v-twin, 48" deck
As you slide down the banister of Life, may the splinters point in the right direction .
Old 09-12-2012, 04:12 PM
Why is the hood touching the gas tank?
Old 09-12-2012, 08:12 PM
CaptMax's Avatar
CaptMax CaptMax is offline
Very carefully loosen the tank holding straps, and center the tank to the hood. Be sure to keep the hood clearance evenly spaced, then tight the straps. If the hood is skewed look for another. There isn't much clearance but there is enough.
CaptMax
Old 09-12-2012, 11:34 PM
Thanks CaptMax. Matt, now I think it's vibration from loose latches. The sides were more rubbed than scratched. Thanks fellas.
Old 09-13-2012, 09:53 AM
mmzullo mmzullo is offline
Wrong gas cap?
