Old 05-11-2012, 11:08 AM
themaddhatter themaddhatter is offline
Default Best price on Quietline mounts?
Finally have some time to get into both of my 1450s, and they both need motor mounts (of course).
Been looking around the internet, and it looks like it is pretty common to find the new style OEM mounts for ~ $20 a corner.
Just wanted to check in and see if anyone has a source for a little better price (yeah, I am cheap).
Don't want to play roulette with the moog mounts, as I really hate doing something more than once (probably one of top 5 pet peeves).
Thanks in advance
Old 05-11-2012, 11:12 AM
dje22's Avatar
dje22 dje22 is offline
You could save a little money by using all of your top mounts from both tractors on one tractor. Then get a new set for the other
David
1200 w/ 44in deck
1000 w/ yanmar diesel.... in progress
Old 05-12-2012, 01:35 PM
Thanks David for the tip!
I have pulled the engine, cradle & mounts out of one 1450, and the top ones don't really seem to get worked at all, while the bottoms are pancakes...
Didn't know the original mounts were the same top & bottom (mine were so mangled you couldn't really compare).
I have seem the pics of the "new" mounts, and those don't seem the same top & bottom. Correct?
Old 05-12-2012, 01:44 PM
dje22's Avatar
Yeah the old ones can go on top or bottom. I used my top set and four more from another tractor last year when i did my mounts on my 1200. The new ones are shaped different. I dont think you can swap them top to bottom.
David
1200 w/ 44in deck
Old 05-12-2012, 03:55 PM
The bottom and tops are not the same.
Old 05-12-2012, 08:24 PM
racenitro racenitro is offline
Don't forget to do the ISO Mount update. Weld the cross brace and your mounts will last a lot longer and you will not damage your mounting bolts int he pan...hopefully they are not already damaged.
Old 05-12-2012, 09:23 PM
I just did my second one in a week!!
I think that little bar is the most valuable upgrade you can do to a QL!!
When I unbolted the engine before I loosened the ISO mounts, the 2 bars just flopped down away from the engine!!
Who knows what kind of stress is on those 4 bolts holding the engine!!
Old 05-12-2012, 10:13 PM
Already welded one up and painted it
List still left on that tractor:
- Pull column & rebuild with bearing upgrades (once I get the damn steering wheel off
- Pinch the front axle pivot tight (sloppy right now). Have a bolt and nut, and will bend it back slooooooowly
- Fab new tubing tie rods & drag links & install with heim ends
- Install axle & new front tubed tires
- Replace plastic hydro fan (would love to do U-joint upgrade, but can't find any reasonable parts to do upgrade)
- Drop engine back in, fluids, drop tiller on it, and run it (got to get ground tilled for the wifey)
Then, I can basically do the same to the other 1450 (along with upgrading wiring as I did on the first one).
Old 05-20-2012, 11:35 AM
bkw3614 bkw3614 is offline
I have had the very same question lately, as I am about to bring a new used Cub Cadet 1250. I am new to the Cub Cadet world too, and would rather PLAY with the Cub Cadet than work on it. That being said, it looks like CC Specialties has a set of motor mounts that have worked well for others without the cost of the OEM part. I have surfed the net as well, looking for the answer, and this is the best price I have found.
I live in Minnesota, too. Now I want a 104, or similar gear drive machine. I am enjoying not taking my medication.
Old 05-20-2012, 12:16 PM
I wasn't happy with the MOOG mounts. Went out paid for the cc ISO mounts and wasted time and $ on the MOOG mounts. I spent $25 more then the cc ISO mounts and twice the time and work.
