Old 04-14-2012, 09:29 PM
HawkEyeEarl HawkEyeEarl is offline
Default cub cadet 1650 rpm and drawbar question
Hi
What would be the normal rpm to run mowing - say up in rabbit position?
And what would be the low idle rpm to want in the turtle position?
I want to try to adjust my cables on my 16 hp kohler to good work positions from idle to work levels.
Also, where is a diagram to show hook my drawbar from the lift connection back to the 3 point hitch lift. I am wondering just how to fit the movable piece at the end of the drawbar to the hydraulic lift.
Thanks
Earl
Old 04-14-2012, 11:44 PM
Originally Posted by HawkEyeEarl View Post
Hi
Thanks
Earl
Earl you want 3600 WOT and I think Idle is 1200. It's in the service manual in the tech section of the site or you could download the engine manual from Kohler's site.
Old 04-15-2012, 06:18 AM
Default thanks for the rpm answere
Duke
I appreciate the help.
Are you running 3600 WOT when you are plowing ground?
I have plowed much ground as young feller many years ago using Farmall's like H's, M's, MTA's, and others - tobacco, corn and garden ground. It is nothing short of amazing to me to see you plowing ground with a 1650 in the videos I watched yesterday as well as you did. I had heard the plows mentioned but still wondered how good a job could be done with a cub cadet. Those videos showed you cutting a good furrow and turning over a good piece of dirt.
Thanks again,
Earl
Old 04-15-2012, 07:49 AM
The Service Manual states for the "best" cooling of your engine, running at WOT is recommended. I always run mine WOT until I am ready for a shut down.
Old 04-15-2012, 09:28 AM
Duke
Thanks again,
Earl
Your welcome Earl! The ground we plowed was a briar patch before the bush hog took care of it. We were tearing threw their roots. I've got to go out there today and do some tilling so I'll get you a video of the tiller in action.
These are so well built and designed that they are true work horses. I've never been disapointed by the work they can do.
I do it just like Roland does.
