Old 04-05-2012, 05:15 AM
4SPEED's Avatar
4SPEED 4SPEED is offline
Default Head Lights for a 125
if I put lights in my 125 , do I need to change the cast iron grill?
and for the wiring should I just find a harness for light.
listing of 2 , 1 has a mount between the lights.
http://www.ebay.com/itm/CUB-CADET-12...item4aaf134fc4
http://www.ebay.com/itm/CUB-CADET-12...item56463de3f8
Doug
Original , 100 , 125 , 582
Old 04-05-2012, 08:00 AM
No, that piece on the first one is the voltage regulator bracket that's on every grille casting.
Old 04-05-2012, 08:28 AM
4SPEED's Avatar
thanks Matt, im still learning
Doug
Old 04-05-2012, 11:29 AM
No need to change the grill out, just get a light set, they will bolt up where the blank cover bolts up to ( the four little 1/4" bolts near the hood bolts). Ive done the wiring on mine "homemade", used a toggle switch and ran the wires along the wiring harness. I put the toggle switch where the lighter would go in the dash, that way I didn't have to drill any holes. Works great
Old 04-05-2012, 01:19 PM
There is a wire in the harness already for lights.It is the color purple.One end should be at the v/r taped to the harness and the other is in the dash tower taped to the other end of the harness.there is a 3/4" hole on the left side of the dash tower for the switch.It is there to protect it from elements.
Old 04-05-2012, 03:49 PM
4SPEED's Avatar
cool , thanks. if I deside to put light in it , now I know the wire should be there. and is all plug & play.
what about the correct switch? still available?
Doug
Old 04-05-2012, 04:08 PM
There are nla from cub cadet New ones go for $90 from outside sources used around $20 to $40 on pee bay.
Old 04-05-2012, 04:14 PM
4SPEED's Avatar
thanks, I'll see what I can find at the tractor shows this year.
Doug
Old 04-05-2012, 09:34 PM
I used a pull switch ( similar to factory ) that I purchased at Auto Zone. The hole is already drilled in the dash ( left side when you're sitting ) and I made up my own wiring.
Old 04-05-2012, 09:40 PM
4SPEED's Avatar
I was thinking the same , getting a new switch . then try to find the pull/push knob at a swapmeet.
jeff did you get any mail today?
Doug
