Old 02-28-2012, 04:25 PM
Saltydawg's Avatar
Saltydawg Saltydawg is offline
Default Ross steering
I am working on rebuilding the steering on my 109. I upgraded the jam nuts to a thrust bearing and nylock nut and also replaced the plastic bushing in the top of the column with a shoulder bearing. The question I have is what kind of material is the D-shaped seal made of ? This steering box either did not have one or it has long since descentegrated(sp).
72 Cub Cadet 109 S/N 435384
^^^undergoing a refurbishment^^^
71 Cub Cadet 149 S/N 410929
Old 02-28-2012, 04:57 PM
It is kind of a thin foam like substance. Not very hearty.
Old 02-28-2012, 05:09 PM
Saltydawg's Avatar
I am thinking of cutting one out of an old inner tube. Any reason it would not work?
Old 02-28-2012, 05:13 PM
SwampRatt-1977's Avatar
that might be a little stiff and could cause it so rub to hard and wear through the steel piece. i used some crafting foam, from any craft store. Hope this helps
Old 02-28-2012, 10:54 PM
Ridgerunner97 Ridgerunner97 is offline
You can get that part at the dealer still for a song and dance. I rebuilt the box in my 123.
Old 02-29-2012, 10:09 PM
RChristensen RChristensen is offline
Inactive Member
I use that material that contractors use on houses between the concrete stem wall and the wood frame. It is the right thickness and seems to last a long time.
Old 03-01-2012, 04:31 AM
72-149's Avatar
72-149 72-149 is offline
there is a pice of tin that gos on top of the foam that is the same shape,hears a pic of what all should be there ,patton has that foam pice for $4.99
File Type: jpg $(KGrHqJ,!ioE8QSu6-C0BPN(6iLMJg~~60_57.jpg (28.5 KB, 175 views)
Old 03-01-2012, 09:32 AM
5 Cub Cadets 5 Cub Cadets is offline
Cool Inner-tube?
The inner tube might not be the best material, because it has a tendency to "swell" when exposed to petrol-based products !?
Old 03-01-2012, 06:48 PM
Saltydawg's Avatar
OK I've been convinced that the inner tube is not the way to go. 72-149 thanks for the picture, that gives me a good idea of what their made of. The picture in the parts manual leaves a lot to be desired.
