The brown truck was here and brought me this. I got it shipped from Amazon for $44.20. We will see how much butchering has to be done to the front plate to install.
982D kwik-way loader w/3 spool control and front and rear remotes,2182, 1812 cat 0, 1440 puller, 3185 grass killer, 2x 450s, QA42, 364, tiller |
I never wanted to dig in and chop up the plate so I went with one of these. I simply attach it to one of those appliance timers and have it turn on about a few hours before I need to get out and clear the driveway.
heater.jpg Even though I do have a NOS CC lower heater hose heater and a NOS CC battery warming mat, I think this was the easiest for me. Let us know how it goes.
1989 - Cub Cadet 1772 1987 - Cub Cadet 1572 w/Rear PTO & Cat. 0 38" Lawn Sweeper #196483 42" L42 (Bush Hog) Rotary Cutter # 190349 45" 2-Stage Snowblower # 196364 48" Haban Rotortiller Rear PTO Driven #190356 54" SnowBlade with hydraulic Angle #196376 60" Haban Mowing Deck #196374 |
got the old one out pretty strait forward. got the new one put in head and hogged out the hole in the plate and put some paint on it. heres a pic of the hole in the head. post more pics later paint is drying rite now so i took a break.
Coming right along. Will there be any problems with clearance between the cord for the block heater and the pulley/fan belt for the fan?
oh yes there was clearance issues
first pic is from top second is from front i wraped a hose around the cord so it dont rub thru
few more pics of the hole in the bracket i used a drill and a die grinder to make hole and radiused the edges to try to avoid future cracking
actually went pretty quick maybe took 1 1/2 hours to do. got called back to work for a week i guess so ill have update on how it starts next week or so
i found this while i was in there looks like a PO had the fan bracket break and or crack and had it welded looks like its holding up fine to me
Why didn't you get one for the block? I see a freeze plug on the side just behind the injection pump......
J i have future plans for that real estate
Ok......
Whatcha gonna do with a second pump? It already has a pump...... ![]() |
