I found a front axle from an 1872 that was in a barn fire. The tires didn't burn all of the way off and the engine was still good (the carb melted). The paint burned off the frame but didn't warp the frame. My question is, how much heat would it take to weaken the cast iron or other parts of the steering assembly (spindles, steering arm, tie rods)?
The seals in the steering cylinder melted also.
Chip T. Drexel NC |
I don't think I'd worry about it as long as it doesn't have any cracks in it from cooling off quickly...it's likely no worse than than heating an axle with a torch to remove a rusted pivot pin. Being that the whole thing was more or less heated at the same time, it should be ok. I've seen a few tractors that were burnt and rebuilt.
Thanks, that was kinda what I was thinking.
Chip T. Drexel NC |
