Old 08-26-2009, 02:46 PM
ole 147 ole 147 is offline
Default Trying to ID an engine
Here I am again.
I'm trying to figure out the HP of my eng . The id plate is totally wiped from a previous owner. All can make out are 2 sets of embossed #
The top # is E0166428
The bottom # is 46407D
Single cyl.
Any one have a clue?
Thanks in advance
ole 147
Old 08-26-2009, 04:18 PM
The Spec Number "46407D" indicates it is a Kohler K-241 10HP
Old 08-26-2009, 04:35 PM
MBounds's Avatar
MBounds MBounds is offline
Roland is correct that the 46407D is the Engine Spec number for a K241. The other number is the engine Serial Number with the E prefix representing a year of Manufacture of 1969 (the last year Kohler used letter prefixes) and the numerals representing the one-up serial number.
Myron B
CCSupplyRoom
Old 08-27-2009, 03:41 PM
Thanks guys for your help!
Duh, Why didn't they just put that in the mod # instead of that other mumbo jumbo.
It would have made things sooo much easier.
ole 147
Old 08-27-2009, 08:05 PM
MBounds's Avatar
Ole 147:
1) The serial number style is just their way of numbering the gazillions of engines they made.
2)The Spec (ification) Number is also necessary because Kohler made those engines for hundreds of different manufacturers and other applications which had their own specific requirements, so Kohler uses the spec number to identify the exact characteristics of any particular engine. The one you cited is only for a K-241 found in a Cub Cadet (per IH specifications!).
3) That's why...:biggrin2.gif:
Myron B
CCSupplyRoom
Old 08-27-2009, 10:13 PM
MBounds,
So your saying that if you just bought an old engine you could look up the spec. # and tell what the engine originaly was put in (cub cadet, jd, ect...)??
Old 08-28-2009, 08:05 AM
MBounds's Avatar
Diz.. Pretty much - in theory... Unfortunately, the Kohler K-Series Manual only generically defines where you find the Specificatins Numbers and what they look like. I have never seen a listing showing who/what Kohler made that specification for...Don't think that there is a such "look-up" listing from Kohler or anyone else. Researching the TC parts manuals can give you the Spec Numbers for Cub Cadets and I imagine a John D**** dealer might be able to do the same for the Kohlers used in their machines, but that's trying to do it the hard way - chasing down each manufacturer that ever used a Kohler... For instance - Bolens, Jacobsen, Montgomery Ward, etc., are dead...They can't tell you anything...
Myron B
Old 08-28-2009, 07:33 PM
Tom S Tom S is offline
The Kohler parts look up does show what a lot of the spec numbers OEM use was. Not all, but a lot of them. Just click on the model number and you get a whole list of the spec numbers and some of the uses.
