When i bought my 982, I noticed wear from the rockshaft cam against the mower mounting bracket. Both parts have worn more than I'd like to see. I have attempted to limit the rocksahft cam's downward rotation with the cam stop, but wear still occurs from the float function. Any suggestions?? Thanks.
It actually doesn't look that bad to me. You could replace that link. Maybe put a washer between the link and the lift arm, then the link would rub against the washer.
Thanks, but I do not think that would help. I can't imagine that this issue was not contemplated during design. I adjusted the links, and that has seemed to help a bit.
I wonder if something's bent. That should clear...
No wonder, i was looking at the wrong part. Like matt said something must be bent or installed wrong.
