Old 09-18-2011, 05:49 PM
cafezwak cafezwak is offline
Default Trans. belt diagram
I'm in the process of installing a new engine on my LT1045 cub. I think I may know how to install the Trans belt but I'm unable to find any site for a diagram how it should look, any help would be great.....
Old 09-19-2011, 06:32 AM
Vince_o Vince_o is offline
When you put the new eng on dont bolt it up till you have the belt on both the tranny and eng pullies.
Once you have the belt on both pullies, then bolt in the eng. FROM HERE ALL REFERANCES ARE FROM YOU SITTING IN THE SEAT.
Your belt belt should have slid more to the right of the steering, if it isnt youll burn the belt up in 30 sec, ask me how I know.
Then look at the two idlers on the right side, one is a v and the other is flat. Push, and watch your fingers, the belt past the guides so that the flat side is on the flat idler, and the v in the v pullie. Youll have to move them around with your other hand to get them in. Once you have that in place look straight across and youll see one more idler, just slip it on.
MTD pays 1 hour to do the job. First time will take a little longer. The key to the job is the belt threw the guids, that you cant see up in the frame around the steering. When you think you have it all in place, trun it with your hands to see if its rubbing nanything. Pull the plugs out of the eng so it turns past TDC easier.
Il keep my eye on this thread if you have any more questions. Frank and I have thought about doing a video and putting it on you tube. Hes doing one now with a tranny rebuild.
Old 09-19-2011, 05:15 PM
Thank you for the help so far, I should be installing the engine and drive belt buy this Thursday. I'll let you know how it goes. I know a YouTube demo would be a good idea since there is nothing out there now showing how to do it.
..al..
Old 09-19-2011, 08:39 PM
Ill see if theres any drive belts to do tomorrow and if there is Ill take some pics of the routing and post them here tomorrow or wed.
Old 10-03-2011, 07:29 PM
Everything is back together and running great. Already mowed the lawn twice. I will keep checking back if anyone else needs help changing out there engine or needs information on changing a drive belt.
I now have some answers for others!!!!!!!
Old 10-03-2011, 08:03 PM
Awesome news! Now back to enjoying your cub!
Old 10-03-2011, 10:44 PM
That's awesome! Glad you got it back together and mowing.
