Old 06-25-2011, 06:01 PM
Default "New" 1250 with troubles
Well I did it again! Couldn't let em' put the old dog down, so I rescued another one from death. Wonder what I was thinking!!
So I now need the advise of the experts on a problem I've got with it. It turns over very well with a new battery, but I've got no spark. Changed the normal things, put on a coil from another tractor, condenser, new spark plug, and a plug wire from another tractor. Nothing. Also cleaned the points, nothing!
What am I missing here? Wires are all good, nothing out of place.
HELP!!!
Old 06-25-2011, 06:04 PM
IROCKWITHDIRT's Avatar
IROCKWITHDIRT IROCKWITHDIRT is offline
Getting 12V to the coil? While cranking?
Wore out 129. Projects: 1969? 147, 1971 chevelle SS conv 402/4sp bench, 1965 chevelle wagon, 1973 trans am drag car, 1973 triumph 650 chopper, and oh yeah, working on the house too!
Old 06-25-2011, 06:13 PM
Yes it is.
Old 06-25-2011, 07:36 PM
Is the ground strap from engine to frame intact?
Old 06-25-2011, 10:19 PM
Hey Matt, I gave it a quick look around the sides, front and back and see nothing. Would it be underneath? If so I'll have to raise it up tomorrow to look.
Think that could be the trouble?
Old 06-25-2011, 10:27 PM
There should be a fairly heavy ground strap from the right front corner of the engine to one of the right side grille casting bolts. That might be the problem because the engine isn't grounded through the engine mounts.
Then again, that might have been a stupid question...if the starter cranks over, it's grounded somehow.
Is your new spark plug for sure good?
Old 06-25-2011, 10:34 PM
I took it out of one of the other tractors that run. Not technically "new" didn't want to run 4 miles for a new one. So you're thinking the ground would'nt be the problem? What about the regulator? I've never worked on one of these, newer ones before. Isn't that the little box with the three wires going to it just to the left and back of the coil.
Old 06-25-2011, 10:39 PM
Todd congrats again! The tins look to be in pretty good shape! A little sun faded but other then that it looks great! You'll ahve it running in no time!
Old 06-25-2011, 10:43 PM
Think so Duke? Hope you're right!! Still have this no spark problem though.
Old 06-25-2011, 11:01 PM
I had to make sure so I looked ast your pics again and the tins are in good shape! Got side panels? Even the rust didn't look to bad. You'll get it figured out!
