Old 05-20-2011, 10:21 PM
staylor1650's Avatar
staylor1650 staylor1650 is offline
Default cub 100 blues
i just bought a cub 100 thats been nothing but trouble it has set to my knowledge a very long time nobody could get it running the po said he got the starter gen rebuilt before he parked it so i hooked a battery up to it and sparks flew from the starter gen so i took it apart and a wire was touching the housing because a brush was in sideways, secondly it made a knocking noise when i turned it over so i drained the oil and its watery but it has this goey metallic stuff in the plug i took my magnet found out its magnetic am i looking at a possible broken rod
75 Cub Cadet 1650
64 Cub 100
not cub but its yellow 62 allis chalmers b-10
Old 05-20-2011, 10:32 PM
william1041200's Avatar
All the rods are aluminum. Magnetic parts inside are the block, crank, crank bearings , camshaft, camshaft pin, lifters, valves, piston rings and piston pin. There is a steel pin through the governor gear,and that gear may be plastic, may be cast iron. How about balance gears? Does your engine have those? I can't imagine how you have magnetic material in your oil. Can't wait to find out what it is.
104 to 127 conversion with dual 6x12s, hydraulics
snow/dirt plow
1200 Quietline 44" mower
QA-36 snow thrower
