Old 05-11-2011, 09:30 AM
jmixa's Avatar
jmixa jmixa is offline
Default kt17 cyl./m18 cyl.
Does anybody know if the cylinder jugs on the Kohler kt17 are the same as the ones on a Kohler m18? I found the part number for the m18 cylinders, but the number for the kt17 is not listed anymore.
Thanks
Jim
Old 05-11-2011, 11:29 AM
ajgross ajgross is offline
Inactive Member
M18 cylinders should work on a kt17 II but I don't think they will work on a series 1. Kt cylinders won't work on a m18 do to them not having the mag mount.
AJ
Old 05-11-2011, 02:36 PM
jmixa's Avatar
Ok thanks! I know that the m18 has the mag mount on only one cly jug but the other one is the one I would need if I dont need the one with the mag mount it should still work correct? I checked the bore and the measure the same.
Thanks for the info
Jim
