Hello all,
It's been a while since I participated because of work and family. For the past several months, my 1450 would shake at start up(violently) and shake while mowing the yard. So I dug into it to investigat and low and behold there were some engine mount bolts missing from the isolater mounts...not the isolater bushings them selves but the engine oil pan bolts. Started disassembly ![]() ![]() Undid the driveshaft and the engine lifted right out! There were no harware securing the engine to the frame! ![]() As you can see the isolater mounts were well intact(they had new busings) ![]() There was one bolt that broke off into the engine but it came out easily(thankfully) ![]() ![]() Notice I wear gloves..ain't I a sissy! LOL! Take care!
Thats a perfect example of why the engine rail mod is so critical. You could have ruined your oil pan, driveshaft and flex joints too. Good thing you pulled it when you did.
I did the cross rail mod and new ISO bushings a few years back. Earlier this summer after mowing I lifted the hood to watch as I idled the engine down and saw it shaking around. Shut it off and found only 1 bolt holding the engine to the rails. I replaced them all with loctite this time. I don't remember if I did that when I did the mod.
I like pie |
You use the blue or red loctite,blue is easier to remove is why I asked,with all the vibration was wondering if red would be better?
If you do decide to use Red (permanent bad stuff) you need to use heat to break it loose with if ever need be. I think blue would be just fine in this situation, however clean the bolt good, and the threaded hole, I use a small brass brush on a drill to clean out threaded holes, then use some alcohol on a q-tip to clean threaded hole, clean the bolt with alcohol as well, this will give maximum effectiveness for locktite type chemicals.
Hope this helps for future breaking loose of any bolts/screws etc... The red is bad stuff |
I'm with Clint...use the blue....you may need heat to loosen the red stuff, and that's not really an option for that area in the tractor.
