Old 10-22-2010, 12:55 PM
Mizar N68X Mizar N68X is offline
Default Original transmission "KNOCK"
Hello OCC Group,
My CCO has a transmission noise.
It is not really that bad but wanted to know if the thumping noise is normal or am I due for rebuild. Most noticabally in 1st and reverse.
Also my CC 70 has the same noise but just in 2nd gear.
Thump Thump Thump....
Old 10-22-2010, 01:04 PM
I would take the shifter off and see if any of the gears are missing a tooth.
Old 10-22-2010, 08:02 PM
Thank you for the reply Matt!
OK I will pull the shifter tomorrow.
If I do not find a bad gear, could it be a bad bearing?
Is there a ring gear like in a car rearend?
Is it possible that the mower sat with moisture"Water" in the trans and rusted a spot on the gear?
Old 10-22-2010, 08:13 PM
Ahh,
Thumping noise,More than likely and more likely, your first and reverse idler gear is missing some teeth.Or you are missing a tooth on the first and reverse gears...or both.
Old 10-22-2010, 10:36 PM
Ahh,
Well that just stinks!!!
OK Darkminion, I will let you guys know what I find.....
Old 10-24-2010, 08:42 PM
Hello Group,
I have not pulled the rear end cover or the shifter to see what is making the noise yet but thought since I was going into town tomorrow I would get replacement oil-fluid for the rear axle so it would be on-hand for when I do.
What gear oil should I buy for the rear axle of my original CC?
Thanks in advance for your reply.
Oh. Is the rear axle cover gasket available at CC dealer?
Old 10-24-2010, 08:47 PM
Hytran. The rear cover gasket can be obtained from CC or from a CaseIH dealer, same for the the Hytran. You can also get Hytran from a Case construction equipment dealer, too.
